Via cad 2D Plasma cutting
What Via cad software would be good for plasma cnc ? The plasma cnc I am getting comes with Fusion 360, and after trying it, I think I hate it. I think a 2D program would be better and easier
Thanks: 351 times Was thanked: 257 time(s) in 169 post(s)
I guess you need a G-Code for your CNC-Machine. Create first a 2D Drawing in 1:1 and convert it to G-Code. Maybe you can use:
https://www.cadkas.com/dxf2gcode.php or you have already a CAM-Software?
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
ViaCAD 2D would work fine. Export as a .dxf r12 into a CAM program, to
generate G-code. I use SheettCAM, very easy to use.
https://www.sheetcam.com/ Larry
(91kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
