Thanks: 7 times Was thanked: 4 time(s) in 3 post(s)
I have tried sharkcad and am happy with most of the functions, but simple thinks irritate me a little bit. If I draw an rectangle (size dont matter ) - how do I then position a circle from one of the corners within the same rectangle? Should I draw a circle in the corner and then moved it horizontal position and then move again in vertical position to get it where I want it? Thank you in advance! Best Regards, Leif Rosenbæk
Hello Leif, Try checking out the PrecisionPoint video in the help menu. You reference a point via the cursor and type in dx,dy,dz values. Tim
Ordinary translation also has data boxes on the header with deltas. Tim, how about angular/distance, vector translation option too?
