removing holes from solid
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
So I made some holes in a solid using the Subtract Solid tool. However, I realized I placed them incorrectly and need to move the holes. When I try to select them, it's only selecting the whole solid, not the hole, which doesn't let me move them. How can I either select these to adjust their positioning, or eliminate them from the solid entirely, so that I can re-place them where they need to be? Thanks!
Was thanked: 47 time(s) in 23 post(s)
Are the subtracted Solids extruded sketches? If yes, simply move the sketches to the correct position. If you wanna delete the holes, just "select deep" the holes and press delete.
I made a set of Cylinder Primitives in the sizes I need, and have been copy/pasting them onto the solid I'm subtracting from. I can manipulate these until I click off the solid, then they become part of it, and I can't seem to separate them. I've also tried drawing a center point circle and using push/pull to make the hole, as well as using the hole tool, but I get the same result - click off the parent solid and it seems to be inextricably linked to the parent, and I can't move it around or delete it. Even with Select Deep. So maybe I'm doing this wrong?
Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
The best method , if possible, is to start from the beginning using the hole tool.
The holes can be moved, deleted and even the hole size, depth and type of hole can be changed.
I know it's more work, but helps when changes are needed.
If you need a lot of holes, a pattern will help, but more difficult to edit.
(116kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
I tried using the hole tool, but it's the same result. I made a simple solid box, put a hole in the side with the hole tool, and as soon as I click onto something other than the hole, I can no longer select just the hole. If I use the Select Deep tool, I can select the hole, but I can't move it anywhere. I get the snap-to lines when I try to drag the center point of the hole to a new location, but when I release the mouse, the hole simply disappears. Either I'm missing something critical here, or this is really buggy.
Thanks: 8 times Was thanked: 74 time(s) in 37 post(s)
Holding down the "Option" key will associate a point with the hole, move the point and the hole will follow.
mitchb attached the following image(s):
(458kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked mitchb for this useful post.
Originally Posted by: mitchb Holding down the "Option" key will associate a point with the hole, move the point and the hole will follow.
That did the trick. Thanks!
