Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Don't know if this will happen on your Win 10 system, but after installing,
Update for Microsoft Windows (KB 4514357), my About display was corrupted.
After un-installing the update, the display returned to normal.
Edited by user Friday, September 27, 2019 10:55:01 AM(UTC)
(103kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Why don't you upgrade to Win10 1903?
Just finished, took 3 hours.
Had to update manually.
(47kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
