jbskaggs
#1 Posted : Monday, September 16, 2019 10:08:41 PM(UTC)
jbskaggs
I have a project that requires me to export all layers as the exact same view, rotation, and zoom.
Problem one: there is no png produced if I try to export that way so using jpg, then having to edit jpg in gimp.
Problem two: I need to be able to return to the exact zoom, rotation, location and view of drawing. I have not figured a way to do that so far. Help please?
Ea product has 32 layers that go into a "paperdoll" product builder on website. I have dozens of different products each with same number of layers. It can be a real challenge to get different products view, size, rotation, and zoom perfect.
Edited by user Monday, September 16, 2019 10:09:46 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, September 17, 2019 1:29:30 AM(UTC)
Hello,
Here are my tricks to get pictures :
1 : I use screen grab of Phong with edge... It is good enough for me with a large display.
2 : You can create new view in the "view" menu to save view angle. For zooming, make a large sphere bigger than your biggest object, zoom all, and hide the sphere before picture.
Workarounds...
Edited by user Tuesday, September 17, 2019 1:30:05 AM(UTC)  | Reason: Not specified
#3 Posted : Tuesday, September 17, 2019 9:12:16 AM(UTC)
I did a quick check regarding exporting PNG images from drawings and all seemed ok. What version of the product and OS are you using?
murray
#4 Posted : Tuesday, September 17, 2019 4:15:43 PM(UTC)
murray
View properties gives the technical definition of what's on screen. The box has provision to name it uniquely there and you recall it from View:User view. You can physically scale views in sheet layer viewports if needed.
Edited by user Tuesday, September 17, 2019 7:24:47 PM(UTC)  | Reason: Not specified
