#1 Posted : Sunday, September 15, 2019 1:33:34 PM(UTC)
Was thanked: 60 time(s) in 51 post(s)
Any ideas?
CONSTRAINTS DISAPPEARING.mp4 (374kb) downloaded 16 time(s).
Shark CAD + Power Pack Pro
#2 Posted : Tuesday, September 17, 2019 9:32:33 AM(UTC)
Was thanked: 220 time(s) in 192 post(s)
Any ideas?
Would it be possible to provide a sample file or steps to repeat?
Vice President Software Development
#3 Posted : Tuesday, September 17, 2019 9:52:42 AM(UTC)
Hi Tim I'll send you the file, but basically it's just gone mad. Worked fine up until a point and then started doing this.
Had it before where you click auto drag a box around the lines etc and they all collapse into on pile.
I'll send it later.
#4 Posted : Tuesday, September 17, 2019 10:06:31 AM(UTC)
Ok thanks, will look at right away. It kind of looks like the coordinate system associated with the sketch is confused. Each constrained system has a local coordinate system.
#5 Posted : Tuesday, September 17, 2019 10:30:02 AM(UTC)
Steps to repeat. Turn on work plane snaps. Draw a non horizontal line and stick a horizontal constraint on it. You'll see the 'slots' layer doesn't have any sketches. This is because it started going mad and I could do them.
Also you might be interested that task manager thinks it's viacad pro 9 and also when it crashes it says the same thing.
TCT00033_tim.vcp (2,653kb) downloaded 2 time(s).
#6 Posted : Tuesday, September 17, 2019 9:31:51 PM(UTC)
When we add a constraint, we would regenerate everything in the model flagged for regeneration.
If anything did not regenerate, it would undo/remove the constraint you are trying to add thinking it had invalidated the model.
Your model has two cover surfaces that are marked for regeneration but fail. I noticed that the failed covers do not have anything to do with the constraints you are adding.
So I've made two modifications that should help going forward.
1. If a previous covering operation fails on regeneration, it will now display an error dialog box at the time it occurs. Previously it did not.
2. When we add/update a constraint, we now only regenerate the applicable sketch system, and all entities dependent on that sketch. We no longer require the entire model be able to regenerate to add/update a constraint.
Still testing more cases, but this looks safe to make a 1442 build.
Edited by user Tuesday, September 17, 2019 9:38:08 PM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, September 17, 2019 9:32:41 PM(UTC)
That should be fixed in the 1441 build. I'll double check with the guy who did that change.
#8 Posted : Tuesday, September 17, 2019 10:59:27 PM(UTC)
Hi Tim, thanks for checking it out.
#9 Posted : Monday, September 23, 2019 12:02:10 PM(UTC)
@Tim, Here is an example of the constraints folding up
Folding Constrains.mp4 (723kb) downloaded 6 time(s).
