fatoftheland
#1 Posted : Saturday, September 7, 2019 11:58:26 AM(UTC)
fatoftheland
version 9 of 2d3d
When i create a drawing for construction it will not create it if i drag model to sheet onto a top view. it will create a sheet if i rotate the object.
once the sheet is created I cant get rid of the construction lines. Am I missing something obvious. (newbie question)
Thanks jon.
#2 Posted : Sunday, September 8, 2019 2:54:11 AM(UTC)
Was thanked: 228 time(s) in 156 post(s)
Do you use the Model to sheet function or copy and paste your construction in a draw view? You should use different layers for your construction and if you want get rid of some kind of lines you should put them on a layer. For Layers please use the Concept Explorer. You can then just deleting the whole layer with the construction lines or making it invisible or select all lines of a layer with the select mask.
