L. Banasky
#1 Posted : Tuesday, August 20, 2019 11:10:04 AM(UTC)
L. Banasky
Getting tired of seeing this, SharkCAD 10 Pro P.C.
Now when I do anything I Export as SharkCAD Version 9, and also
as a .sat file, just so I can open it again.
Importing the file sometimes works.
I'm now going to use Version 9 all the time, Version 11 is
CRAP and not useable, Version 10 is going downhill and no support.
This file is damaged!.jpg (20kb) downloaded 0 time(s).
magicart
#2 Posted : Tuesday, August 20, 2019 11:55:09 AM(UTC)
magicart
Poland
Hi Larry,
I feel Your pain, I heard it happens when the software crashes and You restart PC after that. Always reopening the file is required after software crashes.
Magicart
posh.de
#3 Posted : Wednesday, August 21, 2019 10:13:55 AM(UTC)
posh.de
Undos are probably the most common reason for corrupting a model additionally unnoticed until the next file open. Saving periodically to a dedicated file e.g. by adding a serial number "xyz.01.sfx" etc. and using these documents if a former revision of the model is required instead of using the undo function is recommendable.
thanks 2 users thanked posh.de for this useful post.
magicart on 8/21/2019(UTC), MPSchmied on 8/22/2019(UTC)
magicart
#4 Posted : Wednesday, August 21, 2019 11:02:19 AM(UTC)
magicart
Poland
You have 100% right!!! After 6 years with SharkCad I'm afraid of three things: Undo, Links, MTS :-)
Magicart
Edited by user Wednesday, August 21, 2019 11:03:08 AM(UTC)  | Reason: Not specified
thanks 2 users thanked magicart for this useful post.
jlm on 8/21/2019(UTC), MPSchmied on 8/22/2019(UTC)
L. Banasky
#5 Posted : Wednesday, August 21, 2019 1:32:53 PM(UTC)
L. Banasky
I think another problem is that I GROUP and UNGROUP assemblies to edit parts. If I lasso an assembly
that I UNGROUPED, and then GROUP, works fine.
If I SELECT ALL and GROUP, Shark crashes.
#6 Posted : Wednesday, August 21, 2019 2:14:01 PM(UTC)
Magicart
I fully agree with you Magicart !
Undo, Links, MTS
Many cases have been reported...
GARLIC on 8/21/2019(UTC)
magicart
#7 Posted : Thursday, August 22, 2019 5:20:32 AM(UTC)
magicart
Poland
Originally Posted by: L. Banasky Go to Quoted Post
I think another problem is that I GROUP and UNGROUP assemblies to edit parts. Larry
Hi Larry,
grouping is another never ending topic. I abandoned this function many years ago when I so this action makes a lot of tools doesn't work correctly. I prefer to group object using layers - for example put the whole assembly I want to group on one layer and that's all. I can select all, move all, rotate and make all group invisible just clicking the layer instead of group it... about dozen bugs less.
Magicart
thanks 4 users thanked magicart for this useful post.
jlm on 8/22/2019(UTC), GARLIC on 8/22/2019(UTC), MPSchmied on 8/22/2019(UTC), L. Banasky on 8/22/2019(UTC)
