Rendering & Display
printing to pdg with phong or gouraung in Sharkcad Pro v11
Thanks: 94 times Was thanked: 69 time(s) in 39 post(s)
Hello,
According to the new feature - printing model to sheet with internal lighting views - I noticed there is a huge difference between what I see on the sheet before printing to pdf and after. Before printing to pdf is a nice drawing with edges (I selected phong with edges) and good lightning. After printing to pdf edges dissapear and whole drawing looks not such good. See the files attached. An ideas why it happens?
Magicart
(593kb) downloaded 6 time(s). magicart attached the following image(s):
(407kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Hello magicart Can you attach the PDF file. Regards Jason
Sure, pdf attached
magicart
wydruk9.pdf
(1,813kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Hia All,
after one hour with this issue I've found the workaround how to get rendered MTS drawing with edges (visible and invisible). See the file attached.
Magicart
2.pdf
(716kb) downloaded 16 time(s). 12.pdf
(678kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Rendering & Display
