Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I currently have VC 2D/3D V9. If I upgrade to V10 or Pro can I transfer my custom toolbars?
Thanks: 264 times Was thanked: 131 time(s) in 101 post(s)
1. Install The new Program
2. Go to the folder: C:\Users\yourusername\AppData\Local\Punch!\
3. Copy the config files from the Folder for VC9 to the Folder for VC10.
Maybe this works only after you have already changed some settings in the fresh installation. But it should work. I moved the settings also between Shark Cad and Shark Cad Pro, but when making this is a renaming of some config files necessary.
Edited by user Sunday, April 22, 2018 6:52:28 AM(UTC)
Try copying: VC3Prefs.ini to VCPPrefs.ini VC3Dialogs.ini to VCPDialogs.ini if you have shortcuts... VC3Shortcuts.ini to VCPShortcuts.ini Tim
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Where are custom tool pallets stored in Mac?
see here: /Users/xxxxxxx/Library/Application Support/com.encore.viacadprov10esd/PalletPos.sys
Rokoko, Thanks! But "PalletPos.sys" seems to be a Windows 10 file or folder. I'd try copying it to ...Library/Application Support/com.encore.viacadprov11esd if that existed. Any ideas as to where VCPro11 Application Support would be?
