L. Banasky
#1 Posted : Saturday, July 13, 2019 4:41:58 PM(UTC)
L. Banasky
SharkCAD Pro 10 PC, any way to make the box larger?
I need to select one of the Times New Roman fonts
out of the six available.
Make selection box larger.jpg (46kb) downloaded 2 time(s).
#2 Posted : Sunday, July 14, 2019 2:46:45 AM(UTC)
I bet there's a size for that in the. ini files somewhere. There's one called dialog.... Something maybe try that one first?
L. Banasky
#3 Posted : Sunday, July 14, 2019 5:44:49 AM(UTC)
L. Banasky
Thanks UG,
Searched the .ini and dialog files, and didn't really
find anything that I could edit.
Maybe I should post in suggestions, with examples of
other software handling of long named fonts.
Thanks again,
Like AutoCAD.jpg (36kb) downloaded 0 time(s).
Like CorelDRAW.jpg (54kb) downloaded 0 time(s).
Like Sketchup.jpg (37kb) downloaded 0 time(s).
#4 Posted : Sunday, July 14, 2019 6:27:48 AM(UTC)
Yeah turning on selectfontdialog shows a little bit more but not a lot. They need to make it resizeable like the concept explorer, and then you can edit the .ini file to a preferred size.
SELECT FONT.jpg (61kb) downloaded 0 time(s).
