#1 Posted : Sunday, June 30, 2019 7:18:35 AM(UTC)
I use the most time Shark LT 9 1162, because the in stream zoom commands works there better (multiselect while using a tool like the extruder) But if i have a tube the MTS drawing no line. The Wireframe View works in the same way. So Shark 9 1162 is not 100% Shark 12.....
Edited by user Thursday, July 4, 2019 6:33:59 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, July 8, 2019 8:04:27 AM(UTC)
Today works the MTS for tubes again. It is a miracle. Maybe a Windows Restart fixed the problem. I restarting my windows sometimes a month or 2 or longer not. I disabling always the windows update by deleting
Code:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wuauserv
and make windows update every half year.
Edited by user Monday, July 8, 2019 8:06:11 AM(UTC)  | Reason: Not specified
