I am using a MacBook Pro with ViaCAD Pro 11. I created a 2d drawing of a pneumatic circuit for my customer. They asked for the drawing in AutoCAD 13 and pdf. I am able to export the drawing to AutoCAD 13. But when I save as a pdf i have a blank page. Anyone having an issue like this?
I included a sample drawing.
Sample Drawing.vcp
(577kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 172 times Was thanked: 157 time(s) in 107 post(s)
Selected all and EXPORTED as 3DPDF, not really a great output.
Sample Drawing.pdf
(2,785kb) downloaded 2 time(s). L. Banasky attached the following image(s):
(110kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 7 times Was thanked: 68 time(s) in 34 post(s)
To save as a pdf you need to set it up to print, then instead of printing save as a pdf.
SampleDrawing.pdf
(426kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked mitchb for this useful post.
Thank you for the replies, I appreciate it. I know how to print and save as a pdf. When I do these steps in the preview window the screen is blank. So when I save the document as a pdf file I end up saving a blank document. Not sure if there is a bug in ViaCAD pro11 or maybe a printer driver error. Other documents print from other programs print without errors.
I'm working in ViaCAD V11. If you are getting a blank document then you need to set it up in Page Layout.
(1,574kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked mitchb for this useful post.
