How to reset rotation centre to selected object
                When you option-click an object, you set the rotation centre for the Dynamic Rotate tool. Even if you select another object after this, it will still rotate around the first object. But now I would like to go back to the default: rotation around the centre of the screen, when nothing is selected/rotate around the currently selected object. Option-clicking in an empty space doesn't reset the rotation around the previously object selected with option-click. Does anyone know how to reset to default (except for restarting the program).
Sven
Edited by user  Tuesday, June 4, 2019 4:45:26 AM(UTC)
 | Reason: Not specified
                Have a look at the inspector tool bar under the gripper bit. You can select centre of part you pick, or user position and all this. Might be what you're looking for?
                Inspector -> Gripper reselect 'Centre of Selected'
    Bill Bedford
                Thanks for the replies.
                 The option-click is just a point in space.  It can happen in a point in the part but it doesn't select the part the same way the gripper does.  You can either dynamic rotate without selecting an object with the gripper or select an object with the gripper and then do dynamic rotate.  When you say "I can't rotate", are you referring to the part or the view?
                Ah, there is some confusion. I don't want to rotate the part, I want to rotate around the part. The Gripper has really nothing to do with this, but I now understand why the comments refer to the gripper. It's about rotating around the object that is in the middle of the screen. Not rotating around a point outside of the screen.
                On step 6.  Not sure why you want to rotate again.  Is this a separate click on the dynamic tool after you have done in step 3 and seeing the right half.
If you click twice on the icon twice, the part rotates automatically on the screen about its centroid.  Called autospin.
So I moved the cube to see the right half.  But why rotate again.  I think you need to end the dynamic rotate for you to move the cube with the gripper.  Not sure how your rotating the cube either.  You need to use the gripper to move it.  Maybe do a video.
Edited by user  Friday, June 14, 2019 11:31:26 AM(UTC)
 | Reason: calling the function
                Please forget about the Gripper. I don't want to move the object. I want to move around  the object, to approach it from another side. I'll do a video.
                I think your question is how to revert to no point after using the option click so that it rotates natural relative to the center of the screen.  You went around the gripper so everything is about the gripper from everyone's comment.  I think you need to option click to the origin so that the view rotates natural else it stays on the point you option click. it doesn't revert automatically.
Edited by user  Friday, June 14, 2019 12:02:45 PM(UTC)
 | Reason: added period
                Originally Posted by: macnavi  Okay.. That really helps understand your beef.  There's a way to reset the view when you have panned to the left but I can't remember right now.  Have to remember that one.  For now, you can use the navigator under the pull down window and use the spherical ball that will rotate the screen better.
(13kb) downloaded 0  time(s). You cannot  view/download attachments. Try to login or register.
                Nope. That is not my issue. If I wanted to move the object in view again, I would just hold the space bar to move the whole thing.
                It has to do with your field of view.  There's a way to enlarge it but can't remember that's why it won't do around but only up and down.   The navigator tool will do it however.  Did you try it?  That will do up and down and around.  Maybe you have not used the navigator tool.
                Hm, no, it has nothing to do with field of view. With all respect, it seems to me you don't understand what this option-click function does.
                LOL. I know what it does.  I've been using this longer than you have.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
