Thanks: 103 times Was thanked: 20 time(s) in 15 post(s)
Is there a limit to the undos? I thought I used to be able to undo many times but for some reason today I could only undo something around 5 times. I didn't change any settings. Are they in the Preferences somewhere? Couldn't located a setting for them.. . please help. Thank you.
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: flatpack Is there a limit to the undos? I thought I used to be able to undo many times but for some reason today I could only undo something around 5 times. I didn't change any settings. Are they in the Preferences somewhere? Couldn't located a setting for them.. . please help. Thank you.
Hello Flatpack,
Some operations are canceling the undo list.
Example :
- Make a solid and modify, add, remove, simplify, blend, shell....the undo list is incrementing ---> you can come back to step 1 by undoing.
- But if you select one solid and chose "Remove links" ---> the entire undo list is wiped off. It is impossible to get the links back or undo any step prior to that.
Maybe Tim or Todd could explain why ?
Regards,
JL
1 user thanked jlm for this useful post.
in general, be careful with Undos which may unnoticeably corrupt your model... do a "Save as..." to a dedicated file (e.g. by adding a serial number "xyz.01.sfx" etc.) before doing this.
Edited by user Thursday, June 6, 2019 4:47:27 AM(UTC)
| Reason: Typo
1 user thanked posh.de for this useful post.
I'd be careful with an undo. Ive done it a few times on a sketch with constraints and it goes all over the place.
Thanks everyone – had no idea that undo's could be wiped out by removing links. I would think undo would undo-remove-links. Oh well... At least we have a history-tree normally outside of that.
