I want to draw two plough shares, a side plough and a digger.
I want to draw the shape of the plough blades in 2D to scale and then extrude to thickness.
I am not sure how to do a soft bend, with a big radius. Both blades will require two bends at least.
Edited by user Thursday, April 11, 2019 1:14:55 PM(UTC)
Regards Johan Crous
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
You can draw the 2d shape, extrude, and use the Curve Bend tool,
if this is what you are looking for.
Upload a sketch for ideas, and what version you are using.
Edited by user Thursday, April 11, 2019 5:25:33 PM(UTC)
(104kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thank, I will try. I am using Viacad Pro 11. Just upgraded from 9.
Regards Johan Crous
