WILLIAML
#1 Posted : Tuesday, April 9, 2019 2:57:43 AM(UTC)
WILLIAML
Very new user
Hello ?
If I import a step file, how do I break it up into just flat shapes to export as DXF or DWG to use in another 2D CAD Package.
Ta
Wullie
ken
#2 Posted : Tuesday, April 9, 2019 3:46:40 AM(UTC)
ken
I usually just right click on the model and then you will have an option to convert it into curves which you can use to export as dxf.
L. Banasky
#3 Posted : Tuesday, April 9, 2019 6:43:42 AM(UTC)
L. Banasky
Was thanked: 163 time(s) in 112 post(s)
Originally Posted by: WILLIAML Go to Quoted Post
Very new user
Hello ?
Ta
Wullie
If you just want certain parts, you can OFFSET SURFACE, SILHOUETTE CURVE and EXPORT.
Edited by user Tuesday, April 9, 2019 6:46:03 AM(UTC)  | Reason: Not specified
STEP OUTLINE.sfx (942kb) downloaded 4 time(s).
STEP OUTLINE.jpg (42kb) downloaded 0 time(s).
WILLIAML
#4 Posted : Wednesday, April 10, 2019 10:14:57 AM(UTC)
WILLIAML
Sorry, I should have mentioned that I am using ViaCad.
#5 Posted : Thursday, April 11, 2019 9:06:00 AM(UTC)
Hello William
What version of ViaCAD?
#6 Posted : Thursday, April 11, 2019 9:24:17 AM(UTC)
Hello
You can also use explode curve tool on each surface.
STEP OUTLINEopt.vc3 (2,322kb) downloaded 6 time(s).
Annotation 2019-04-11 112018.png (186kb) downloaded 2 time(s).
WILLIAML
#7 Posted : Friday, April 12, 2019 9:52:24 AM(UTC)
WILLIAML
Hello
ViaCAD V9.09 Build 1184
#8 Posted : Friday, April 12, 2019 10:05:38 AM(UTC)
Hello
Hello
Download the file I posted and see the results of the explode curve tool.
