Very new user Hello ? If I import a step file, how do I break it up into just flat shapes to export as DXF or DWG to use in another 2D CAD Package. Ta Wullie
I usually just right click on the model and then you will have an option to convert it into curves which you can use to export as dxf.
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
Originally Posted by: WILLIAML Very new user Hello ? If I import a step file, how do I break it up into just flat shapes to export as DXF or DWG to use in another 2D CAD Package. Ta Wullie
If you just want certain parts, you can OFFSET SURFACE, SILHOUETTE CURVE and EXPORT.
Edited by user Tuesday, April 9, 2019 6:46:03 AM(UTC)
STEP OUTLINE.sfx
(942kb) downloaded 4 time(s). L. Banasky attached the following image(s):
(42kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Sorry, I should have mentioned that I am using ViaCad.
Originally Posted by: WILLIAML Sorry, I should have mentioned that I am using ViaCad.
Hello William
What version of ViaCAD?
Hello
You can also use explode curve tool on each surface.
STEP OUTLINEopt.vc3
(2,322kb) downloaded 6 time(s). jdi000 attached the following image(s):
(186kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Hello ViaCAD V9.09 Build 1184
Originally Posted by: WILLIAML Hello ViaCAD V9.09 Build 1184
Hello
Download the file I posted and see the results of the explode curve tool.
