Art Smith
#1 Posted : Monday, April 8, 2019 8:47:24 PM(UTC)
Art Smith
anyone have any thoughts on how to "fix" a damaged SharkCAD Pro file? see attached graphic. I have NO idea how it was "damaged"!! what if anything do we know about the 9th position from the end of the file? what do we know about what the program is checking AND how it knows the 9th position from the end is "damaged"??
Art
artesmith@earthlink.net
damaged file graphic.jpg (14kb) downloaded 0 time(s).
#2 Posted : Tuesday, April 9, 2019 9:04:54 AM(UTC)
I had the same message yesterday and sent the file to Tim.
What I did before getting the message :
- Open a relatively complex file (150 Mb) with solids and MTS
- Modify the solid - without saving
- Realise that my modification damaged the links to the MTS
- Close the file - without saving
- Try to reopen it ---> DAMAGED
It is strange that a good file became damaged without any saving.
Strong advise :
"Save as" incremental files as often as possible with beta versions...
Yesterday, I could re-use the previous saving and just lost one working hour.
Edited by user Wednesday, April 10, 2019 9:14:22 AM(UTC)  | Reason: Not specified
Capture d’écran 2019-04-07 à 22.43.54.png (156kb) downloaded 0 time(s).
