flatpack
#1 Posted : Friday, April 5, 2019 7:59:04 AM(UTC)
flatpack
Hi, I've had some issues with ACAD users when I export from Shark to .dwg:
the curves which I've created using the 3-point Conic are seen as splines to the ACAD users.
It needs to be polylines for programming to cut.
Are conics splines? If so, what tools can I use to create curves to that they are exported as polylines? Or - what exporting parameters should i set?
Thanks!
L. Banasky
#2 Posted : Friday, April 5, 2019 10:02:56 AM(UTC)
L. Banasky
Was thanked: 163 time(s) in 112 post(s)
I am not familiar with the 3 point conic, but I've always had
good results exporting as an R12 .dxf for CNC plasma, waterjet and milling machine
files.
#3 Posted : Friday, April 5, 2019 10:17:27 AM(UTC)
Thanks!
Hello
Use the tool in the arc pallet called "Arcs From Curves" Arcs are much better for CNC equipment than polylines.
Annotation 2019-04-05 123940.png (31kb) downloaded 1 time(s).
MPSchmied on 4/5/2019(UTC)
flatpack
#4 Posted : Friday, April 5, 2019 10:21:21 AM(UTC)
flatpack
files.
Thanks Larry, I've been exporting as a 2013 .dwg, 2d flat drawings – mainly because that is the standard they request.
is a .dxf mainly for 3d? Not super knowledgeable about that.
flatpack
#5 Posted : Friday, April 5, 2019 10:22:52 AM(UTC)
flatpack
Ok noted with thanks. Could you kindly elaborate on how it works please? I've never used it before.
#6 Posted : Friday, April 5, 2019 11:30:26 AM(UTC)
I can open 2010 autocad files if you would like me to check them for you? See that we get it right before you go to your customer with it?
flatpack on 4/12/2019(UTC)
L. Banasky
#7 Posted : Friday, April 5, 2019 1:11:31 PM(UTC)
L. Banasky
<<<<<Thanks Larry, I've been exporting as a 2013 .dwg, 2d flat drawings – mainly because that is the standard they request.
is a .dxf mainly for 3d? Not super knowledgeable about that.>>>>>
Mostly for 2d outlines, depends on the CAM program, really 2 1/2 d, the .dxf
files can be used for drilling and tapping, milling pockets and slots etc.
L. Banasky
#8 Posted : Monday, April 8, 2019 5:09:31 AM(UTC)
L. Banasky
Just in case you miss converting to an ARC or LINE.
The EXPORT to r12 .dxf does it automatically.
Example r12 dxf.sfx (14kb) downloaded 0 time(s).
Example r12 dxf.jpg (34kb) downloaded 0 time(s).
#9 Posted : Monday, April 8, 2019 5:33:14 AM(UTC)
Aren't these lines polylines and can have many little lines causing stops and starts if everything is arcs its a much smoother cut.
L. Banasky
#10 Posted : Monday, April 8, 2019 6:36:32 AM(UTC)
L. Banasky
Seems to be a non-segmented line, I've been using the r12 .dxf
export for over 10 years, and the CNC plasma cuts fine.
Really don't know the difference between a Curve, Line, or Polyline.
Just works.
Non-segmented lines.jpg (34kb) downloaded 0 time(s).
#11 Posted : Monday, April 8, 2019 6:39:00 AM(UTC)
Just works.
Yes I guess it depends on the software generating the cnc code, and how it handles splines and polylines.
MPSchmied on 4/9/2019(UTC)
