brian sayer
#1 Posted : Monday, March 18, 2019 12:36:27 PM(UTC)
brian sayer
Hi All
I tried to use the apparent intersect snap to work I know there was a video on this but cannot find it on the forum the link there no longer works.
I select it, it asked too select first curve then select second curve a red line appears between them then nothing happens i'm sure this did work
Just wanted to see the vid to make sure it’s not me doing something wrong.
doesent work with v10 or v11 beta shark Pro.
Brian
rokoko
#2 Posted : Monday, March 18, 2019 1:59:50 PM(UTC)
rokoko
Was thanked: 43 time(s) in 37 post(s)
hi, it works in v10 with the line tool:
brian sayer
#3 Posted : Monday, March 18, 2019 3:22:09 PM(UTC)
brian sayer
Thank you rokoko i was making a real silly error in what i was doing all working fine now i need to make a not
Brian
mitchb
#4 Posted : Monday, March 18, 2019 5:03:22 PM(UTC)
mitchb
Was thanked: 28 time(s) in 16 post(s)
Instead of the Line tool select the Point tool to set a point.
Screen Shot 1.png (536kb) downloaded 9 time(s).
brian sayer
#5 Posted : Tuesday, March 19, 2019 3:14:50 AM(UTC)
brian sayer
Thank you Mitch that could be added to the explination in tim's book on page 22 i thought it automaticly selected the pointplacement.
i hadent used it for a long time
Very Best Regards
Brian
