Rozen
#1 Posted : Monday, March 18, 2019 12:01:02 PM(UTC)
Rozen
Dear Gents,
How can I skin submitted profiles with one guided curve? ( all circles are perpendicular to the guided curve )
See attached file
Thank you in advance!
Leif Rosenbaek
Quote:
Quote:
skinning.sfx (11kb) downloaded 8 time(s).
rockyroad_us
#2 Posted : Monday, March 18, 2019 1:49:47 PM(UTC)
rockyroad_us
you have to use a combination of the one guide skin surface and the guided lofted side unless you have the centerline skin, which is a new command in beta. Not sure which command is the one guided curve you are referring to.
Also, I could not open the file with my commercial license since this was done in some educational license.
#3 Posted : Monday, March 18, 2019 3:35:54 PM(UTC)
The Skin with Guide Curve requires the guide curve precisely touch each profile. Your example represents a centerline path.
Attached is a v11 CenterLine Skin using your curve and profiles.
Edited by user Monday, March 18, 2019 3:38:55 PM(UTC)  | Reason: Not specified
skinningTDO.sfx (127kb) downloaded 6 time(s).
L. Banasky
#4 Posted : Tuesday, March 19, 2019 6:24:31 AM(UTC)
L. Banasky
Was thanked: 161 time(s) in 111 post(s)
Hi Tim,
Is the v11 CenterLine Skin Tool in the SharkCad Pro v.11 Beta?
Can't seem to find it.
#5 Posted : Tuesday, March 19, 2019 8:14:49 AM(UTC)
Yes, it is the last icon in the skin options.
Intro to CenterLine Skinning : https://www.youtube.com/...VN8&feature=youtu.be
Edited by user Tuesday, March 19, 2019 8:16:12 AM(UTC)  | Reason: Not specified
