Thanks: 7 times Was thanked: 4 time(s) in 3 post(s)
Dear Gents,
How can I skin submitted profiles with one guided curve? ( all circles are perpendicular to the guided curve )
See attached file
Thank you in advance!
Leif Rosenbaek
skinning.sfx
(11kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
you have to use a combination of the one guide skin surface and the guided lofted side unless you have the centerline skin, which is a new command in beta. Not sure which command is the one guided curve you are referring to. Also, I could not open the file with my commercial license since this was done in some educational license.
The Skin with Guide Curve requires the guide curve precisely touch each profile. Your example represents a centerline path.
Attached is a v11 CenterLine Skin using your curve and profiles.
Edited by user Monday, March 18, 2019 3:38:55 PM(UTC)
skinningTDO.sfx
(127kb) downloaded 6 time(s). Tim Olson attached the following image(s):
(193kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Hi Tim, Is the v11 CenterLine Skin Tool in the SharkCad Pro v.11 Beta? Can't seem to find it. Thanks, Larry
Yes, it is the last icon in the skin options.
Intro to CenterLine Skinning :
https://www.youtube.com/...VN8&feature=youtu.be Tim
Edited by user Tuesday, March 19, 2019 8:16:12 AM(UTC)
(91kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
