Suggestions
screws and placement (#3567)
Hello Tim,
you offer us the tool hole and screw symbols. (french only?)
Can you offer us, now, a [COLOR="Lime"]real[/COLOR] placement function [COLOR="lime"]pro parametric[/COLOR] type (mechanical) of these screws?
for example using the hole axis and only the bearing surface of the screw, or ... the origin of the symbol as a reference.
Imagine ....: a metal with [COLOR="lime"]many[/COLOR] holes ... hmm? :)
Please.
http://screencast.com/t/bQnEE4YF2 Antoine
(26kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
Where did you get the screw symbols? please, i really need them Luis G. :)
In your build 929 (not in 959) through Concept Explorer
I got that library, but all the 3d screw and nuts are placed as a group of curves and lines, not solid Luis G.
You're right! Why? I have no answer!
When I need a fastener, I go to
http://www.mcmaster.com/ and I download the 3D SAT file. Every time it's perfect!
>>for example using the hole axis and only the bearing surface of the screw Hi Antoine Have you tried the Assembly Insert tool? Tim
hello Tim, yes i'm try, but....it is verrrrry long and not productive for my opinion. 1,2,3,4,5 clics for each screws!!!!!! it's ok for simple and no more pieces, but in the case with ...40X screws, that's a hell.:cool: Antoine
I do the same, download from mcmaster or 3dcontencentral each time I need some, but is slow process and we should have a descent library for this parts, not mentioning some parametric function for it.
Originally Posted by: Tim Olson >>for example using the hole axis and only the bearing surface of the screw Hi Antoine Have you tried the Assembly Insert tool? Tim
Tim, any answer about the 3d library?
Luis G.
the 3d srews library is a French development. :rolleyes: the ideal would be to make parametric! who can? :eek: [COLOR="Red"]with the new tools of constraints[/COLOR] Antoine
Suggestions
