is there any way to get SharkCAD Pro to calculate the moments of inertia of a cross section made from more than one area? and a slightly different question: is there a way to tell/direct SharkCad Pro what X & Y-axis to use for the calculation of the moments of inertia?? see attached graphic
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(39kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hello Art, >> to calculate the moments of inertia of a cross section made from more than one area? No sorry, ACIS wants one closed area. >>is there a way to tell/direct SharkCad Pro what X & Y-axis to use for the calculation of the moments of inertia?? There is no way for the user to specify the x /y axis. Tim
Originally Posted by: Tim Olson Hello Art, >> to calculate the moments of inertia of a cross section made from more than one area? No sorry, ACIS wants one closed area. >>is there a way to tell/direct SharkCad Pro what X & Y-axis to use for the calculation of the moments of inertia?? There is no way for the user to specify the x /y axis. Tim
Tim-
thanks! guess it's back to A x d² with the calculator
Art
