PianoTondo
#1 Posted : Monday, March 04, 2019 4:50:11 AM(UTC)
PianoTondo
Hi Everyone,
I'm going to deal with more difficult tasks.
In this case I'm trying to realize a "complicated" (for me) hollow on a solid object. I'm thinking to create some kind of shape to substract to the main solid but I don't know if it's the correct procedure. I'd like to build the object.
By the way I attach two drafts ( made with Strata 3D and pen ).
What are your kind advices ? :D
Should I use nurbs? I never used them...
Thanks for now, have a nice day!
Edited by user Monday, March 04, 2019 4:52:55 AM(UTC)  | Reason: Not specified
PianoTondo attached the following image(s):
#2 Posted : Monday, March 04, 2019 8:38:14 AM(UTC)
Was thanked: 214 time(s) in 188 post(s)
Yes subtracting a shape is a good approach. If you have smooth edges, follow up with edge blends after you subtract the core.
IMSI Design / Encore
PianoTondo
#3 Posted : Monday, March 04, 2019 8:56:14 AM(UTC)
PianoTondo
Yes It's the first Idea I had with the solids.
But what if I use the Mesh?
The problem is that (correct me if I'm wrong) to work properly with the mesh I should have to buy the powerpack.
Currently is there a way to design segments on a mesh? Once I created the mesh I can't delete or change segment, neither select them.
I'm used to work with mesh cause I usually worked with 3d program based on that kind of procedure, but I can't understand how to make it works in Viacad Pro.
Maybe I need an upgrade? Or is there a tutorial which explain the keymap or how to work freely with mesh?
I saw there is a feature selection in the powerpack which seems to enable the work with segments, faces and vertex.
digitalphaser
#4 Posted : Monday, March 04, 2019 2:49:59 PM(UTC)
digitalphaser
Was thanked: 36 time(s) in 31 post(s)
Mesh modeling with viaCAD is very unusual. PowerPack is responsible for the converting, correction, diagnostics etc. of mesh and has only a few functions for modeling. Do not suffer with it. Take the normal polygon modeler. Or surfaces would be good choice for your sketch.
