Solid Modeling
Align an Object/Group to the main plan
Hi Everyone! I imported a Step File into my project: it was a button composed by two object. The problem is that it was imported completely non-aligned. It didn't have any sense or point of reference, completely askew. So I made a group of the two object and I patiently aligned it by sight with simple manouvers of the gripper. Is there a more precise way to realign an object to the normal plan and coordinates? Thanks as usual! Have a nice day
Thanks: 46 times Was thanked: 298 time(s) in 203 post(s)
https://youtu.be/1GLF2LYvrMA This is what you want. Just make sure you move the rotation point to where it needs to be before you rotate. We'll that's what I do anyway. You may have to put some lines in to rotate against though.
Hi! Thanks for your answer. I'm looking into it. It's not easy and quick but it's seems to be the solution! Thank you very much for your help :D
Solid Modeling
