Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Anyone know if there's a Shark preference for adjusting the number of Undo's you can undo? I want to lower it down to free up some memory if that helps – for certain projects.. If this is available I cant seem to locate it in the preferences. Thanks
>>Anyone know if there's a Shark preference for adjusting the number of Undo's you can undo? No, it is unlimited by default. However, there is an option in prefs to clear the undo when you save. Tim
Originally Posted by: Tim Olson >>Anyone know if there's a Shark preference for adjusting the number of Undo's you can undo? No, it is unlimited by default. However, there is an option in prefs to clear the undo when you save. Tim
Ok cool – thanks!
If I remember correctly the option to clear the undo on save also clears the undo on autosave, which may not quite be what you always want.
Edited by user Thursday, February 28, 2019 1:49:07 AM(UTC)
Bill Bedford OSX 10.14.5 ViaCAD Pro 11 (1429)
