#1 Posted : Friday, February 22, 2019 3:50:07 AM(UTC)
If you in v9 1162 renaming some parts with the inspector will be only the features renamed which are relevant for the cutlist. Therefore are sometimes when some Features used not the Partnames in the Concept Explorer renamed, but the Features which used for the Cutlist. This seems to bee also a bugfix, because it looks not perfect. But this bugfix was unfixed in v10/11. See also: http://forums.punchcad.c...ts&m=37239#post37239
Hello Tim Olson, i am very happy that you are back and working on the great software.
