Thanks: 103 times Was thanked: 20 time(s) in 15 post(s)
Anyone have any experience exporting .obj files to Unity? Or using Shark/VC in general for Unity or UE4? I have a small AR project i've been tasked with and want to use Shark to model the assets. Thank you.
Originally Posted by: flatpack Anyone have any experience exporting .obj files to Unity? Or using Shark/VC in general for Unity or UE4? I have a small AR project i've been tasked with and want to use Shark to model the assets. Thank you.
OBJ is a universal format. The model should be low-poly. Use the manual mesh setting.
You can load OBJ into Blender, clean up the model by removing unnecessary triangles and save as .blend. Unity love .blend as well. :)
Edited by user Wednesday, February 20, 2019 1:47:02 PM(UTC)
(110kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked digitalphaser for this useful post.
Originally Posted by: digitalphaser OBJ is a universal format. The model should be low-poly. Use the manual mesh setting. You can load OBJ into Blender, clean up the model by removing unnecessary triangles and save as .blend. Unity love .blend as well. :)
Thanks for your advice and for the very helpful image. I have to admit, I am VERY AFRAID of Blender. It looks quite intimidating to me. Nothing is “standard” like a normal 3d modeling tool. Do you think that my fears are unfounded?
I like the fact that it’s free, but it doesn’t look user friendly.
Blender is optional. It is just an additional opportunity. In general, for simple operations like removing edges, Blender is quite simple.
>>Blender is optional. It is just an additional opportunity. Another free app you can look at for facet reduction/decimate is MeshMixer. I enjoy the user interface and features . To decimate a model in MeshMixer you would : Select : Modify : Select All Edit : Reduce You then use the sliders to dynamically change the resolution. FYI, we are in the process of replacing the Decimate tool in PowerPack with that of TurboCAD PC. We're also adding mesh booleans based on TurboCAD PC. Tim
Yes, MeshMixer is cool. But it is rather an automatic solution. I meant manual cleaning and validation of meshes. I like to use VC/Shark to model the base form. But free deformation or organic modeling is better to do with mesh. Here is a short video about the possible process of manually converting NURBS to quad mesh:
https://youtu.be/ntRpO2StJ80 Of course this is only one of the possible options. For example for hard surfaces it is not necessary. Shark flexibly enough adjusts mesh.
Originally Posted by: Tim Olson Another free app you can look at for facet reduction/decimate is MeshMixer. I enjoy the user interface and features . To decimate a model in MeshMixer you would : Select : Modify : Select All Edit : Reduce You then use the sliders to dynamically change the resolution. Tim
Thank you Tim – I've not heard of this before. Sounds like what I'm looking for and is worth downloading.
Originally Posted by: digitalphaser Yes, MeshMixer is cool. But it is rather an automatic solution. I meant manual cleaning and validation of meshes. I like to use VC/Shark to model the base form. But free deformation or organic modeling is better to do with mesh. Here is a short video about the possible process of manually converting NURBS to quad mesh:
Nice to see some additional Shark/VC tutorials. So few on YT. Quick question about one of your videos – is this layer nesting only available in Shark Pro? I am currently using SharkCad 10 and don't see this.. (you can see the difference)
Thanks!
edit: also I wish to request if you could please make an intermediate tutorial video on Animation using Shark Pro.
Edited by user Friday, February 22, 2019 9:41:24 AM(UTC)
(6kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: flatpack Nice to see some additional Shark/VC tutorials. So few on YT. Quick question about one of your videos – is this layer nesting only available in Shark Pro? I am currently using SharkCad 10 and don't see this.. (you can see the difference)
I'm glad you enjoyed the video. Strictly speaking, this is not a tutorial. It’s just thinking how VC/Shark can be used for different types of modeling.
Yes, these are sub-layers. I think your screenshot is same thing, but probably another OS.
Originally Posted by: flatpack ...also I wish to request if you could please make an intermediate tutorial video on Animation using Shark Pro.
Sorry, I do not do animation with Shark. This is not my theme.
(72kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
