Good bye WIP Development i go to build 1162
Thanks: 359 times Was thanked: 265 time(s) in 173 post(s)
I tested v9 1162 today and have to say, that the "in stream zoom command" bugs are there not present and the linear-duplicate-bug was fixed, but was not present in v9. The MTS works faster and better with files which not work in v10. The Dimensions-Bug that the next offset value have no effect is still fixed in Shark LT 9 1162. Maybe in 1224 are bugs, i have not tested now and i don´t waste time for testing this. You fixed alot of new created bugs, a new version is a step back. Need i really the curve repair tool and the magnet tool? No. Maybe sometimes you stop going backwards... I watch next year again for it. All other is a waste of time.
V9 1162 is the best release ever.
Edited by user Monday, February 11, 2019 8:04:06 PM(UTC)
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Originally Posted by: MPSchmied ... Need i really the curve repair tool and the magnet tool? No. Maybe sometimes you stop going backwards ...
... a Curve Repair Tool, what doesn't work in most cases ... in 90% of all I must use Join Curve additionally "to repair the repair"
... Magnet Tool, ok works fine for me and it is a Very-Nice-To-Have
I'm going back to Version 10, so I can use furthermore Deform Face and my PowerPack. Version 11 is waste time an money.
horst.w
GER
The "in stream zoom commands" works also in v9 not properly, just the multiselect in Solid-Tools works there, but Multiselect of lines outside works not properly after using a in stream zoom command because after Ctrl released while shift pressed the selection will be deleted. The tangent helpline disappear permanently after Ctrl+F or a "in stream zoom command" used. This Bugs have i already reported. The Tangent Help Lines should stay always also when using a in stream zoom command. And Multiselect should work by keeping the shift key permanent and just releasing the ctrl for end the "in stream zoom command". This issue anger me all the time i used Shark CAD. I guess it is not a new version number worth until this fixed.
Edited by user Tuesday, February 12, 2019 4:27:38 PM(UTC)
And in argon cobalt works the "in stream zoom commands" in the same wrong way. Shark CAD and ViaCAD are still the best. But it should be very much better. There is alot of potential.
Thanks: 94 times Was thanked: 69 time(s) in 39 post(s)
Only one thing I'm really disappointed is the MTS has been going backward since v9. I have expected the v11 will be a step forward, I remember when Tim wrote that he had got "video conference" with SPATIAL to solve most of mts bugs. I thought "at least". But now, when I've been testing Shark v11, I see nothing changed. MTS is the most important module for me and still the most buggied.
magicart.
Edited by user Thursday, February 14, 2019 2:03:28 AM(UTC)
1 user thanked magicart for this useful post.
I understand that the elimination of bugs in 10. version is no longer provided. Is 1370 Build for WIN last?
Was thanked: 5 time(s) in 3 post(s)
My VCP is 1368, where do you get 1370?
Originally Posted by: 3dup My VCP is 1368, where do you get 1370?
I do not remember, but it is a fact.
(67kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Latest release of VCP10 for Windows is 1369 and for mac 1376
Latest release of SharkCAD Pro 10 for Windows is 1371 and for mac 1376
The form to get the download links works again - you can browse this content space manually.
http://www.masterviacad.com/beta/beta.php Edited by user Wednesday, February 20, 2019 3:51:49 AM(UTC)
I cant wait to have the new version in my
domain
