#1 Posted : Monday, February 11, 2019 4:17:10 PM(UTC)
Was thanked: 249 time(s) in 165 post(s)
I tested v9 1162 today and have to say, that the "in stream zoom command" bugs are there not present and the linear-duplicate-bug was fixed, but was not present in v9. The MTS works faster and better with files which not work in v10. The Dimensions-Bug that the next offset value have no effect is still fixed in Shark LT 9 1162. Maybe in 1224 are bugs, i have not tested now and i don´t waste time for testing this. You fixed alot of new created bugs, a new version is a step back. Need i really the curve repair tool and the magnet tool? No. Maybe sometimes you stop going backwards... I watch next year again for it. All other is a waste of time.
V9 1162 is the best release ever.
Edited by user Monday, February 11, 2019 8:04:06 PM(UTC)  | Reason: Not specified
horst.w
#2 Posted : Tuesday, February 12, 2019 3:41:12 AM(UTC)
horst.w
Originally Posted by: MPSchmied Go to Quoted Post
... Need i really the curve repair tool and the magnet tool? No. Maybe sometimes you stop going backwards
... a Curve Repair Tool, what doesn't work in most cases ... in 90% of all I must use Join Curve additionally "to repair the repair"
... Magnet Tool, ok works fine for me and it is a Very-Nice-To-Have
I'm going back to Version 10, so I can use furthermore Deform Face and my PowerPack. Version 11 is waste time an money.
horst.w
GER
#3 Posted : Tuesday, February 12, 2019 4:23:46 PM(UTC)
The "in stream zoom commands" works also in v9 not properly, just the multiselect in Solid-Tools works there, but Multiselect of lines outside works not properly after using a in stream zoom command because after Ctrl released while shift pressed the selection will be deleted. The tangent helpline disappear permanently after Ctrl+F or a "in stream zoom command" used. This Bugs have i already reported. The Tangent Help Lines should stay always also when using a in stream zoom command. And Multiselect should work by keeping the shift key permanent and just releasing the ctrl for end the "in stream zoom command". This issue anger me all the time i used Shark CAD. I guess it is not a new version number worth until this fixed.
Edited by user Tuesday, February 12, 2019 4:27:38 PM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, February 13, 2019 2:13:17 PM(UTC)
And in argon cobalt works the "in stream zoom commands" in the same wrong way. Shark CAD and ViaCAD are still the best. But it should be very much better. There is alot of potential.
magicart
#5 Posted : Thursday, February 14, 2019 2:01:14 AM(UTC)
magicart
Poland
Only one thing I'm really disappointed is the MTS has been going backward since v9. I have expected the v11 will be a step forward, I remember when Tim wrote that he had got "video conference" with SPATIAL to solve most of mts bugs. I thought "at least". But now, when I've been testing Shark v11, I see nothing changed. MTS is the most important module for me and still the most buggied.
magicart.
Edited by user Thursday, February 14, 2019 2:03:28 AM(UTC)  | Reason: Not specified
thanks 1 user thanked magicart for this useful post.
jlm on 2/15/2019(UTC)
digitalphaser
#6 Posted : Monday, February 18, 2019 3:31:32 AM(UTC)
digitalphaser
I understand that the elimination of bugs in 10. version is no longer provided. Is 1370 Build for WIN last?
3dup
#7 Posted : Tuesday, February 19, 2019 12:15:42 PM(UTC)
3dup
Was thanked: 5 time(s) in 3 post(s)
My VCP is 1368, where do you get 1370?
digitalphaser
#8 Posted : Tuesday, February 19, 2019 1:23:02 PM(UTC)
digitalphaser
I do not remember, but it is a fact.
#9 Posted : Wednesday, February 20, 2019 3:46:52 AM(UTC)
Latest release of VCP10 for Windows is 1369 and for mac 1376
Latest release of SharkCAD Pro 10 for Windows is 1371 and for mac 1376
The form to get the download links works again - you can browse this content space manually.
http://www.masterviacad.com/beta/beta.php
Edited by user Wednesday, February 20, 2019 3:51:49 AM(UTC)  | Reason: Not specified
Fakaza
#10 Posted : Wednesday, February 20, 2019 12:26:26 PM(UTC)
Fakaza
South Africa
I cant wait to have the new version in my domain
