Issue in Main-Menue TRIM
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Originally Posted by: UGMENTALCASE That's another complaint going in then!
The next one!
In Main-Menue TRIM I miss a sub-menue point: Simplify Curves
Simplify Curves is part of the tool bar, but the icon is faulty linked as Repair Curves. Both funktions are working normal.
Click to the Main-Menue TRIM >>> OFFSET ... opens a Sub-Menue with 3 options, the last one (new?) is Offset Face Edge.
BUT ONLY one time !!! After using this menue I can't re-open it exept after restarting the program.
In the tool bar it is the same, the Sub-Menue doesn't open, a click to the icon activate the at last called (and faulty fixed) function but not the Sub-Menue. To reach the Offset-Distance or Offset-Point function it needs to restart the program.
horst.w
GER
Edited by user Monday, January 28, 2019 3:14:27 PM(UTC)
(43kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I get the repair symbol change, but it allows me to do it more than once. It still acts as simplify curves. The other offset works fine for me
Yes, I see it and I have really no idea what happened. At the moment it runs and I can change between the 3 function without any restrictions as usual. Alternatively I could not click to a subject to activate the gripper and select it. Feeled 1000 tries and no gripper possible while I have worked with it before. Closing and re-open the window had solved it. H.
