horst.w
#1 Posted : Monday, January 28, 2019 3:13:53 PM(UTC)
horst.w
That's another complaint going in then!
The next one!
In Main-Menue TRIM I miss a sub-menue point: Simplify Curves
Simplify Curves is part of the tool bar, but the icon is faulty linked as Repair Curves. Both funktions are working normal.
Click to the Main-Menue TRIM >>> OFFSET ... opens a Sub-Menue with 3 options, the last one (new?) is Offset Face Edge.
BUT ONLY one time !!! After using this menue I can't re-open it exept after restarting the program.
In the tool bar it is the same, the Sub-Menue doesn't open, a click to the icon activate the at last called (and faulty fixed) function but not the Sub-Menue. To reach the Offset-Distance or Offset-Point function it needs to restart the program.
horst.w
GER
Edited by user Monday, January 28, 2019 3:14:27 PM(UTC)  | Reason: Not specified
Simplify Curves.png (78kb) downloaded 0 time(s).
Offset Face.png (43kb) downloaded 0 time(s).
#2 Posted : Tuesday, January 29, 2019 2:28:23 PM(UTC)
I get the repair symbol change, but it allows me to do it more than once. It still acts as simplify curves.
The other offset works fine for me
horst.w
#3 Posted : Wednesday, January 30, 2019 11:55:48 AM(UTC)
horst.w
Yes, I see it and I have really no idea what happened.
At the moment it runs and I can change between the 3 function without any restrictions as usual.
Alternatively I could not click to a subject to activate the gripper and select it. Feeled 1000 tries and no gripper possible while I have worked with it before. Closing and re-open the window had solved it.
H.
