PianoTondo
#1 Posted : Monday, January 28, 2019 3:50:17 AM(UTC)
PianoTondo
Hi!
This topic is a little complicated to describe, I'll make my best.
Currently I draw in 2D in ViaCad Pro in order to create 3D object.
To do this, I want to fill the area inside polygon or inside closed paths of curves. Then the idea is to extrude the area ( if you know better ways to do this I'll be glad to listen to them :D )
The problem come out when I have an area with holes in it, so I want to fill the area inside without fill the holes, in this way I can extrude a object which already have holes.
I'm not able to do this procedure, because I always fill everything without excluding the hole.
I attached an image where I colored the part I'd like to fill and create a surface ( It's an example image, not very beautiful ).
I hope I was clear and understandable.
Thanks for now, and have a nice week!
F
PianoTondo attached the following image(s):
digitalphaser
#2 Posted : Monday, January 28, 2019 4:21:29 AM(UTC)
digitalphaser
Was thanked: 60 time(s) in 44 post(s)
Select all profiles simultaneously and extrude.
PianoTondo
#3 Posted : Monday, January 28, 2019 5:15:10 AM(UTC)
PianoTondo
WoOoOoOoW! Very nice thanks!
Happy to see that :D
