2D Drafting
Offset to Value without rounded corner
Hello Everyone, I'm new with ViaCAD and CAD in general, I already worked in 3d for years but without this way of thinking. Currently I'm working with the 2D design and interface in order to understand it. I tried to use the function "OFFSET TO VALUE": I have a joined and closed curve composition and I want to create a offset of 2mm So I take the "Offset to Value" command and I create a larger version of my track. The problem is that every corner become rounded. I'd like to have them not rounded but normal. Is there a way to achieve this? Thanks, and have a nice day! F
I'd try it with open curves. Don't close them first. It can do some weird things if they are closed curves.
Originally Posted by: PianoTondo I tried to use the function "OFFSET TO VALUE": I have a joined and closed curve composition and I want to create a offset of 2mm So I take the "Offset to Value" command and I create a larger version of my track. The problem is that every corner become rounded. I'd like to have them not rounded but normal. Is there a way to achieve this?
This is no problem, if you want edges press just Ctrl at the same time when you click for the offset direction. It works also when you press Ctrl before u select curves and release ctrl after click for direction. But if you want selecting multiple curves fith the Shift-Key, you should press CTRL only when select offset direction location.
Watch the Tool hints in the big Prompt, and Data Entry Window .
Edited by user Friday, January 25, 2019 7:40:39 AM(UTC)
Hi! Thanks for your precious help. I'm outdoor now. Tomorrow I'll try both of your advices and I'll make you know :D Thanks again, see ya! F
Ok, I tried. :D It worked using CTRL and open curves. I can't make it work with a jointed curves form. Is it correct ? But is there a way to decide the corner radius ? It's pretty strange that it's everything automatic.
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Reproducing what about here is spoken, I found
OFFSET Faces Edges
but I couldn't find out what this function is doing and how it is working.
Its new (for me) in the sub-menue of Trim... Join ...
HELP doesn't help!
horst.w
GER
Edited by user Monday, January 28, 2019 12:40:07 PM(UTC)
(106kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
It saves drawing a line to offset from. If you wanted to put a hole
a certain distance on a rounded surface you could mark the spot.
Or cut out a section, might be useful.
(76kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Many thanks for clarification!
Horst
Very useful function for me!!!
Edited by user Monday, January 28, 2019 3:24:52 PM(UTC)
(59kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
