Jolyon
#1 Posted : Friday, November 9, 2018 5:34:26 AM(UTC)
Jolyon
Sweep curve along 2 guides - sweep fails to respect drive curve
This has been like this forever - in fact, perhaps there's logic to say it shouldn't work anyway
Be great if someone could look at it and say why the driven curve is not respected
... and can anything be done about it
Thank you !
Jol
sweep 2 guide issue.sfx (16kb) downloaded 13 time(s).
Jolyon attached the following image(s):
2 rail sweep fail.jpg (45kb) downloaded 10 time(s).
thanks 1 user thanked Jolyon for this useful post.
Art Smith on 11/9/2018(UTC)
L. Banasky
#2 Posted : Friday, November 9, 2018 8:30:21 AM(UTC)
L. Banasky
Hi Jol,
Don't know if this is what you want, seems to work on the PC.
sweep 2 guide issue2.sfx (107kb) downloaded 5 time(s).
sweep 2 guide issue2.jpg (116kb) downloaded 8 time(s).
Jolyon
#3 Posted : Friday, November 9, 2018 11:56:34 AM(UTC)
Jolyon
Many thanks Larry !
- Could somebody with a Mac have a look for me
... perhaps this is a Mac / PC thing !?
Or perhaps I'm doing some thing daft ?
Thanks again Larry !
Jol
Jolyon
#4 Posted : Saturday, November 10, 2018 4:37:01 PM(UTC)
Jolyon
Anyone,
Bueller ?
mitchb
#5 Posted : Saturday, November 10, 2018 9:57:56 PM(UTC)
mitchb
Modify your end slope so it's not so sharp.
mitchb attached the following image(s):
Screen Shot 1.png (113kb) downloaded 1 time(s).
Screen Shot 2.png (115kb) downloaded 2 time(s).
Jolyon
#6 Posted : Sunday, November 11, 2018 3:18:30 AM(UTC)
Jolyon
Hi MitchB
I've tried your suggestion - this just lessons the issue, but the issue remains
Perhaps you're on a PC - and this is a Mac issue ?
(I'm not really looking for a workaround. I'm looking to highlight longstanding issues so they can be rectified and not ignored)
I note that your solution looks wavy - I also had this issue in my experimentation
Perhaps if any of the devs go through these forum entries - they can look at that too
Thanks Mitch for your help
Jol
Jolyon
#7 Posted : Tuesday, December 4, 2018 2:57:33 AM(UTC)
Jolyon
tumbleweed
rockyroad_us
#8 Posted : Tuesday, December 4, 2018 1:05:48 PM(UTC)
rockyroad_us
I'm on a mac. I can confirm the same result but only if I go from left to right when picking the curves to sweep. If you pick from right to left and maintain the height with the OPTION key held down, you get a better result with the 2 guide rail sweep. I know Larry attempted it with the guide sweep surface as a solution, which is not the same command and also gives sort of a kink in the surface when you zoom in.
In my CAD experience, it is better you go with four curves instead of three since you still need maintain tangency with whatever this is patching.
#9 Posted : Tuesday, December 4, 2018 1:37:50 PM(UTC)
I've just tried it in shark on a PC, and if I go right to left on the two curves it's almost on the lower sweeping curve. If I go left to right it's way off like the original image.
Tried it in V11 pro and it had a fit, and eventually gave the same results as shark although moving the model around was very jittery after this.
Guided skin surface works ok, but there is a blip in the top of the longer edge for whatever reason...
Edited by user Tuesday, December 4, 2018 1:46:58 PM(UTC)  | Reason: More detail added
sweep 2 guide issue.slt (74kb) downloaded 0 time(s).
rockyroad_us
#10 Posted : Tuesday, December 4, 2018 2:06:22 PM(UTC)
rockyroad_us
Better to go with four curves and do a net surface. Who knows what the calculations might be doing. You suspect it will behave correctly intuitively but the math behind it might not allow it thus you get a space or way off.
Maybe if someone has another spatial engine in another CAD and try out the curves to confirm this.. My Rhino is too old to try.
#11 Posted : Tuesday, December 4, 2018 2:37:18 PM(UTC)
I can stick them through Catia tomorrow but I've done something similar, and got different results. Visually I preferred the Shark result, only because I knew what the resulting surface should have looked like. Although the Catia surface appeared to go away from what I wanted.
#12 Posted : Wednesday, December 5, 2018 12:09:25 AM(UTC)
Straight off the commands Catia can't figure it out. NX however produces a nice surface. It's almost the same as what Shark can do, only the one in NX grips the bottom edge better.
NX 9.zip (1,852kb) downloaded 5 time(s).
NX 9.igs (315kb) downloaded 11 time(s).
NX 9.txt (3kb) downloaded 6 time(s).
rockyroad_us
#13 Posted : Wednesday, December 5, 2018 9:11:26 AM(UTC)
rockyroad_us
You would think that it will be identical assuming they both use the same engine. I don't know much about NX but it does sound like a higher end CAD software. I guess you get what you paid for.
Maybe it is time to start looking around since Punch is going in a different direction and our voices are not heard.
annabel parker
#14 Posted : Monday, December 24, 2018 7:08:31 AM(UTC)
annabel parker
It was really good to read this post and it Dyson Coupons helped me a lot thank for such a useful post keep posting
srafiq
#15 Posted : Wednesday, December 26, 2018 6:09:26 AM(UTC)
srafiq
Pakistan
Thank you !
Jol
The issue has been reported to the development team for a fix.
I'll let you know once it's fixed.
Shaheryar
Edited by user Wednesday, December 26, 2018 6:10:30 AM(UTC)  | Reason: Not specified
Regards,
Shaheryar Rafiq
QA & Support Engineer
Guest (10)
