Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Hi all, I get this warning message when I import a DXF or DWG from Shark into Autocad.
Is this something that can be controlled when exporting from Shark or is this strictly some goofy ACAD thing?
(117kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hello Flatpack What version of dwg or dxf are you exporting as? Can you draw a simple sample - 2d rectangle and export it as dxf in the current version you are using and post it? Thanks Jason
Originally Posted by: jdi000 Hello Flatpack What version of dwg or dxf are you exporting as? Can you draw a simple sample - 2d rectangle and export it as dxf in the current version you are using and post it? Thanks Jason
Thanks, maybe that was the problem. I was able to open a R 2015 dxf file of just a simple 2d rectangle without any warning this time!
Unfortunately for a R 2015 - or any earlier version - of a dwg, I still get the warning. Here's a 2015 dwg attached.
Rectangle Test.dwg
(11kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Can you post the dxf of the older version? Thanks Jason
Originally Posted by: jdi000 Can you post the dxf of the older version? Thanks Jason
Here it is.
Rectangle Test.dxf
(78kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Tried in ACAD 2011 gets an 'incomplete error'
I've managed to open it in 3d object converter program, and it shows a surface. I've had this before ACAD doesn't like surfaces as DXFs for some reason, is this what you have exported?
Edited by user Wednesday, November 28, 2018 2:01:02 PM(UTC)
| Reason: More detail added
(97kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 195 times Was thanked: 163 time(s) in 112 post(s)
The .dxf opens in ACAD 2019 without the warning. The .dwg opens with the warning, and when you continue it's O.K. I've seen this before if you receive a file from someone who uses a Font that is not loaded on your system, and ACAD substitutes one of their choice. Larry
1 user thanked L. Banasky for this useful post.
Originally Posted by: UGMENTALCASE Tried in ACAD 2011 gets an 'incomplete error' I've managed to open it in 3d object converter program, and it shows a surface. I've had this before ACAD doesn't like surfaces as DXFs for some reason, is this what you have exported?
Ok thank you. It looks like it converted it to a surface. I just exported a 2d rectangle. Perhaps exporting as a dxf converts to a surface, I am not particularly knowledgeable about that.
I'll have a play and report back :-)
