flatpack
#1 Posted : Tuesday, November 27, 2018 11:29:06 AM(UTC)
flatpack
Hi all, I get this warning message when I import a DXF or DWG from Shark into Autocad.
Is this something that can be controlled when exporting from Shark or is this strictly some goofy ACAD thing?
ACAD Warning Message.png (117kb) downloaded 0 time(s).
#2 Posted : Wednesday, November 28, 2018 7:42:38 AM(UTC)
Hello Flatpack
What version of dwg or dxf are you exporting as?
Can you draw a simple sample - 2d rectangle and export it as dxf in the current version you are using and post it?
flatpack
#3 Posted : Wednesday, November 28, 2018 9:35:13 AM(UTC)
flatpack
Hello Flatpack
Thanks, maybe that was the problem. I was able to open a R 2015 dxf file of just a simple 2d rectangle without any warning this time!
Unfortunately for a R 2015 - or any earlier version - of a dwg, I still get the warning. Here's a 2015 dwg attached.
Rectangle Test.dwg (11kb) downloaded 2 time(s).
#4 Posted : Wednesday, November 28, 2018 9:45:49 AM(UTC)
Can you post the dxf of the older version?
flatpack
#5 Posted : Wednesday, November 28, 2018 12:04:34 PM(UTC)
flatpack
Here it is.
Rectangle Test.dxf (78kb) downloaded 7 time(s).
#6 Posted : Wednesday, November 28, 2018 1:56:42 PM(UTC)
Tried in ACAD 2011 gets an 'incomplete error'
I've managed to open it in 3d object converter program, and it shows a surface. I've had this before ACAD doesn't like surfaces as DXFs for some reason, is this what you have exported?
Edited by user Wednesday, November 28, 2018 2:01:02 PM(UTC)  | Reason: More detail added
ACAD 2011.jpg (168kb) downloaded 2 time(s).
3d object converter.jpg (97kb) downloaded 1 time(s).
L. Banasky
#7 Posted : Wednesday, November 28, 2018 2:38:26 PM(UTC)
L. Banasky
The .dxf opens in ACAD 2019 without the warning.
The .dwg opens with the warning, and when you continue it's O.K.
I've seen this before if you receive a file from someone who uses
a Font that is not loaded on your system, and ACAD substitutes
one of their choice.
flatpack on 11/28/2018(UTC)
flatpack
#8 Posted : Wednesday, November 28, 2018 3:49:29 PM(UTC)
flatpack
Ok thank you. It looks like it converted it to a surface. I just exported a 2d rectangle. Perhaps exporting as a dxf converts to a surface, I am not particularly knowledgeable about that.
#9 Posted : Wednesday, November 28, 2018 3:51:18 PM(UTC)
I'll have a play and report back :-)
Guest (9)
