#1 Posted : Wednesday, November 21, 2018 7:31:02 AM(UTC)
Was thanked: 303 time(s) in 205 post(s)
Hi, no matter what I do and how perpendicular my lines are to the centre line I get this error. What am I doing wrong?
#2 Posted : Wednesday, November 21, 2018 10:41:12 AM(UTC)
Hello
Its hard to know the context without a pic as to why this alert is triggered.
#3 Posted : Wednesday, November 21, 2018 10:48:35 AM(UTC)
I'll try and get a picture up later. Basically a circle, line perpendicular to it, then a spline wiggly to another line which is perpendicular to a square shape. The wiggly and perpendicular lines are joined, so both shapes have a perpendicular line coming off them, throws up this error. If I select yes, it thinks for a while and does a surface which makes it impossible to turn the model round, really slows it down
#4 Posted : Thursday, November 22, 2018 3:16:31 AM(UTC)
I've made a test file, basically two circles, two lines perpendicular to the circles, and a spline in the middle. They are all separate at the moment, but if you join them and then try it I get the error.
Cheers
TESTER.vcp (20kb) downloaded 11 time(s).
BillB
#5 Posted : Thursday, November 22, 2018 7:20:35 AM(UTC)
BillB
It is still not clear what you are trying to do with these lines
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
#6 Posted : Thursday, November 22, 2018 7:38:53 AM(UTC)
So I started with 2 circles set a distance back from each other, joined with a straight line from centre to centre. Then used the centreline tool and it worked fine.
I've then moved one circle in one direction, and now joined the two circles with the 3 separate lines. If we join those 3 lines I get the perpendicular error. I haven't joined them in the example file so you can see they are both at 90 degrees before we start
Edited by user Thursday, November 22, 2018 7:39:54 AM(UTC)  | Reason: Not specified
digitalphaser
#7 Posted : Friday, November 23, 2018 4:11:09 AM(UTC)
digitalphaser
I like that the file created with 11. version cannot be opened in the old one(I use SharkCAD Pro 10). Most software has long got rid of this disease. Or is it intentional? Very interesting.
#8 Posted : Friday, November 23, 2018 4:14:19 AM(UTC)
Yeah proper ache, even on the starter files it does it and they are saved as a .dat?!?!
Anyway I've attached a version 10 file, but do you have the centreline skin function ?
Untitled 1.vcp (15kb) downloaded 3 time(s).
digitalphaser
#9 Posted : Friday, November 23, 2018 4:28:08 AM(UTC)
digitalphaser
No, the 10. Shark does not have that. But this does not mean that the file should not open.
For example, the old version can skip any unsupported features or freeze NURBs data etc...
But just say it is "incompatible"? I have not seen this for a long time.
#10 Posted : Friday, November 23, 2018 5:17:26 AM(UTC)
Hello
The program has never allowed opening of files in versions older than the file was saved in. That is why there is file export as ViaCAD /Shark and you can pick the version so it can be opened in older versions of the program.
BillB
#11 Posted : Friday, November 23, 2018 5:58:33 AM(UTC)
BillB
There are no lines in this file only 3 planes
The v11 file showed the three lines you were interested in as continuous and I had no problems joining them with join curve tool.
Bill Bedford
OS X 10.13.6
#12 Posted : Friday, November 23, 2018 6:02:12 AM(UTC)
Yeah we join them, then try the using them as the guide for centreline sweep, the new function in version 11. Although that's interesting that was a open file, export to version 10, and it's not taken the lines with it!
digitalphaser
#13 Posted : Friday, November 23, 2018 6:25:09 AM(UTC)
digitalphaser
Hello
Yes. :) Thanks, I did not know that I can export native files. I had no need to do this. It is not usual. And by the way, I did not see the opportunity to export to ViaCad from Shark. Although in fact *.sfx and *.vcp are same files with different extensions. This makes communication very difficult. Although... vC/Shark is not very common software.
#14 Posted : Friday, November 23, 2018 2:00:00 PM(UTC)
Soooo getting back to it, has anyone successfully managed to do this?
L. Banasky
#15 Posted : Friday, November 23, 2018 2:51:52 PM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
Is there a Demo for ViaCad 11 Pro? I have the PC Beta, and as of yet, there is no centerline sweep icon that I am
aware of.
murray
#16 Posted : Friday, November 23, 2018 3:24:03 PM(UTC)
murray
ViaCAD 2D3D/Pro natively opens Shark's .sfx files of the same or earlier version, likewise Shark opens ViaCAD 2D3D/Pro files as native, they also interchange natively with TurboCAD Mac's .tcd files. I expect that TurboCAD Mac opens PunchCAD files too. On the basis of all of those permutations, it wouldn't surprise if there's commonality amongst all of those with Ashlar/Vellum/Cobalt files too. Almost a de facto neutral format.
Edited by user Friday, November 23, 2018 3:25:35 PM(UTC)  | Reason: Not specified
#17 Posted : Friday, November 23, 2018 3:38:35 PM(UTC)
aware of.
The icon is inside the ruled surface icon. You click it and get the extra tool bar and its in there. Swoopy looking thing
L. Banasky
#18 Posted : Saturday, November 24, 2018 9:22:41 AM(UTC)
L. Banasky
Replaced your lines with a spline, seemed to work.
Answered yes to the line pop up.
TESTER2vcp.vcp (34kb) downloaded 1 time(s).
Tester with Spline.jpg (95kb) downloaded 5 time(s).
#19 Posted : Saturday, November 24, 2018 9:37:42 AM(UTC)
I have changed the joined lines to the other options, but not drawn over the lines with a spline, is this what you did?
L. Banasky
#20 Posted : Saturday, November 24, 2018 1:25:28 PM(UTC)
L. Banasky
I just did an approximate draw over of your lines, nothing precise.
