CAD Fan
#1 Posted : Saturday, November 17, 2018 12:59:03 AM(UTC)
CAD Fan
I have a part that has to be swept across two different paths and I can not find any way to do it, I even tried a two rail sweep! I would greatly appreciate any advice on how to go about modeling this complex part.
CAD Fan
complexsweep1.vc3 (456kb) downloaded 13 time(s).
GARLIC
#2 Posted : Saturday, November 17, 2018 7:29:11 AM(UTC)
GARLIC
Was thanked: 103 time(s) in 65 post(s)
Hi CAD Fan:
First of all you have to take the 2 rail curves, which consist of 3 parts each (straight line+arc+straight line) and transform these
into a single curve: go to-
Modify/Trim/Join Curve
Now you will be able to extrude along these 2 curves,
good luck !
Jolyon
#3 Posted : Saturday, November 17, 2018 9:05:17 AM(UTC)
Jolyon
Can the radius on the upper 'corner' get bigger ?
If so - perhaps you need only follow the (lower) single guide curve
(once joined as suggested)
If not, you'll get distortion at the corner using these two guides as shown
(but maybe that's what you want >?)
rockyroad_us
#4 Posted : Saturday, November 17, 2018 11:12:00 AM(UTC)
rockyroad_us
Originally Posted by: GARLIC Go to Quoted Post
Hi CAD Fan:
good luck !
When you do that, the continuity is distorted on the opposite sides of the curve. To keep continuity you have to do it in three sections and join them together. That occurs even with the option feature to maintain height.
Another thing I noticed is that the width between the lines in the lower end is bigger than the other pair in the upper side. I doubt that can be manufactured that way. It appears as if the horizontal portion is to be made smaller. I would think that distance should be the same.
CAD Fan
#5 Posted : Tuesday, November 20, 2018 10:50:27 AM(UTC)
CAD Fan
Thank you all for your help, the problem is resolved
rockyroad_us
#6 Posted : Tuesday, November 20, 2018 7:42:21 PM(UTC)
rockyroad_us
It will help others if you posted what you did right or wrong so others can learn from this question.
Antoine
#7 Posted : Wednesday, November 21, 2018 3:42:58 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hello CAD fan,
could you show us the result?
Antoine
