Hi All,
Sorry to be late in response to your thoughtful comments. I am referring to molded parts. I do many 3D prints in the prototyping phase, but my wall thickness issues are with the molding process.
Plastic injection molded parts typically have a specified wall thickness. Where the thickness is reduced, the hot plastic melt has a higher resistance to flow and can result in thinner areas where the mold is not completely filled, and even voids where plastic never actually flows into that part of the mold.
Where the walls are thicker (effectively at wall junctions, etc.) the plastic takes longer to harden and typically results in 'sinks' where the cooling plastic shrinks and causes a dimple on the outer side of the wall.
So it is important to strive for constant wall thickness which also helps in the reduction of cycle time.
It is difficult to design constant wall thickness in very complex 3D parts. The tray image attached has complex traps designed to quickly capture pills to deliver exactly 7 pills into a weekly pill organizer. The design of those areas is messy, much too complex for the Thicken Wall tool.
The second image is a wall thickness tool at Shapeways. It shows that my part has some areas that are thin with respect to 3D printing standards, and what I am requesting in ViaCad is a similar tool but would hopefully indicate thickness throughout the part, probably a color display. If a central surface were generated, distances from all points on that surface to the outside surfaces of the part would be very helpful for designing parts to be injection molded.
I haven't found rockyroad's suggested Thickness tool in Powerpack; is that in a Shark version of Powerpack?
I normally use two infinite planes located close together, one rotated 180° and both set as clip planes. Two of these on the left of the object while viewing with two viewport layouts. As the two selected infinite planes are moved up and down, the wall thickness can be viewed. To scan vertically, use two infinite planes above the object and scan horizontally.
PRP attached the following image(s):
(401kb) downloaded 0 time(s).
(369kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
