                Hello Tim,
I repeat my question which dates from long ago ...
Indeed, the decals pass through solid in rendering mode.
Can you fix this problem stp?
Thank you
My old post
http://forum.punchcad.com/showthread.php?t=1969 la mouche attached the following image(s):
(237kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Yes Tim - surely there is a Lightwork switch for this !? Of course there is always a workaround - but this is fundamental - a decal sits on a surface ... it does not go through a solid like Brighton Rock !
                A couple years ago when I had this problem I think I put a new offset surface to put the decal on.  Would love to see this fixed though. Art  Shark FX
                Yes Tim - this one needs sorting for the next release !!
                Unfortunately this is a Lightworks constraint.  I've asked Ryan to check with Lighworks tech support to see if anything is being done on this issue or if we are doing something wrong with our implementation. Tim
    Tim Olson  IMSI Design/Encore
                Tim?... please! leave Lightworks Antoine
