problem with printing text
Thanks: 16 times Was thanked: 8 time(s) in 7 post(s)
Hello,
this morning, i have problems to print.
in the drawing layer, reverting looks fine.
After i make a preview vor pdf, all the text in the drawingarea is 'double
spezial the dimensions.
please see the screenshots
a.wieneke attached the following image(s):
(27kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hello Andreas Is the setting scale annotation size in the print setup checked or unchecked? Regards Jason
hello Jason, sorry, i do not understand, what you mean, what string scale....... usually i go to file>page setup, after to file>page layout : align center and everything is fine. the double text is only in the text in the drawing area.
