Quite a long time there was a strangeness in the display of objects.
Strange rifts appear on the surfaces. Resolution is Super Fine. What is it?
(113kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Yeah.. I get them too. When it happens, I'll attach a picture. I thought it was my graphics card working hard. The alien graffiti goes away when I change the setting on the resolution to precise facets.
Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Originally Posted by: digitalphaser Quite a long time there was a strangeness in the display of objects. Strange rifts appear on the surfaces. Resolution is Super Fine. What is it?
Yes, I get this too on the latest MacBook Pro.
Originally Posted by: rockyroad_us ...I thought it was my graphics card working hard...
I am not sure with the graphic card.
Previous 10- versions worked fine on a less powerful machine with the usual average GeForce card.
Now I have a good configuration for graphics and 3D work with nVidia Quadro.Drivers are always new. I set the maximum settings for SharkCAD and will be watching. :)
Precise facets resolution is bad for large projects. It slows down the computer calculation. I try to avoid this feature.
(114kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Video card settings did not help get rid of artifacts. But if I open another 3D application at the same time, SharkCAD is extremely retarded. I can barely navigate and move objects. Shark turns into a sleepy fly. :) I often open several programs at the same time, Keyshot + 3D-Coat or zBrush or Photoshop and it does not affect the performance. At least I do not notice the restrictions.
