m.marino
#1 Posted : Monday, September 10, 2018 4:53:24 AM(UTC)
m.marino
Tim and crew,
I know you are working on version 11 and testing the beta versions out. One suggestion is adding more printers or adding a somewhat easily usable set up tool that allows for a permanent storage of a different printer. My reasoning is that currently I build my models in Shark Pro v11 and then export them to Slic3r PE which allows me to use both my Prusa printers and my deltas without any serious issue. Currently the printer set up doesn't really allow that. I don't know if it is important or not on goals for the software and to be honest i would prefer more usable CAD tools and being able to assign materials a bit easier (That and be able to set up BOM a bit easier).
So while it is an idea the other points hold equal if not more importance. As that would make getting billing to clients much easier on me.
Hope you folks are doing well and look forward to v11 coming out.
SharkCAD Pro v10 w/ PowerPack Pro
Lenovo D20 2x E5620 w/ 64GB RAM, Nvidia 1060
OS: Windows 10 Pro x64
MM0MSU
#2 Posted : Monday, September 10, 2018 9:39:32 AM(UTC)
You can add your own printer, with size of bed and name and stuff, you just need to edit the 3d printer file with your info.
Cheers
