Thanks: 46 times Was thanked: 303 time(s) in 205 post(s)
Hi All,
I'm trying to bend this wire rope model around an arc. I've tried numerous different ways but can't seem to bottom it. It's as you would expect the end of a wire rope to look as it bends back on itself to be secured. Any help would be great!
I've only put one spiral in as the file size was quite big, so if you just polar duplicate say 3 of them, you should get a pattern of a few which is ready to bend
Cheers
Edited by user Wednesday, September 5, 2018 5:29:00 AM(UTC)
wire ropes.vcp
(1,847kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 141 times Was thanked: 141 time(s) in 100 post(s)
I rotated and copied about the Z axis, if you increase the diameter of the cable slightly 4 rotations
should do it. I did more than was needed and trimmed them.
Just an idea, hope it helps.
Edited by user Wednesday, September 5, 2018 6:15:35 AM(UTC)
(49kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Cheers, I can do that one, it's bending the other way. Check this link. it's the loop bit I'm trying to make.
Sorry wasn't very clear in my waffle
https://uk.rs-online.com...yvD_BwE&gclsrc=aw.ds
Curve Bend Tool should get you on the right track. Will probably
take some experimenting.
(58kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Looking good, it's the height axis and all this I couldn't get my head around
Got it, bending everything to everything now! Cheers for the help
... bending like beckham !
Better bending than him!!! :-) It's just confusing when it asks for heights and stuff. So I did a little practice piece. A long round bar, and a curve/arc. Pick the solid, then pick the curve you want to bend it to the shape of. The pick end points on long round bar (start centre point, end centre point), then pick end points of arc (start point of arc, end point of arc), and hey presto! I was thinking the heights where, in my case, the diameter of the bar or something, but after some fiddling I figured it out.
