brian sayer
#1 Posted : Tuesday, August 28, 2018 6:15:54 AM(UTC)
brian sayer
Hi All
I am having a problem selecting a new colour what ever i do i cannot select anything from more
only from the colours provided is there a bug or am i doing something wrong i am sure i had no problems in the past with this.
All the best
Brian
brian sayer attached the following image(s):
flatpack
#2 Posted : Tuesday, August 28, 2018 7:44:55 AM(UTC)
flatpack
Was thanked: 20 time(s) in 15 post(s)
Originally Posted by: brian sayer Go to Quoted Post
Hi All
All the best
Brian
I had that problem this morning when I tried to change a notation color. I just deleted it and started over. Thought it was just me.
brian sayer
#3 Posted : Tuesday, August 28, 2018 10:13:05 AM(UTC)
brian sayer
This is when trying to create a new line i want to use a diferent colour to the bog standard ones and it will not let me should i report this as a bug?
L. Banasky
#4 Posted : Tuesday, August 28, 2018 10:35:07 AM(UTC)
L. Banasky
Hi Brian,
Double click on the Default Pen Box, Choose a color on the next box,
and then Add to custom colors.
Custom Colors.jpg (101kb) downloaded 4 time(s).
brian sayer
#5 Posted : Wednesday, August 29, 2018 4:31:35 AM(UTC)
brian sayer
Hi L. Banksie
yes I have done that as well but this will not allow you to add that colour to the inspector defaults colour for a new line so will not allow me to create any more line colour than the ones shown.
this does not allow you to fill in a colour from the more option giving the RGB numbers
the only way I can find to do this is to place an object then select it and change the object properties so the colour then with selecting the eye dropper selecting an object with the colour you want and giving this style to the lines selected This is a work around but not a solution.
I hoped I could be add directly to a new object like you can with weight and styles?
Brian
Edited by user Wednesday, August 29, 2018 4:37:41 AM(UTC)  | Reason: Not specified
Screen Shot 2018-08-29 at 11.22.04.png (33kb) downloaded 0 time(s).
Screen Shot 2018-08-29 at 11.33.21.png (111kb) downloaded 0 time(s).
L. Banasky
#6 Posted : Wednesday, August 29, 2018 6:43:58 AM(UTC)
L. Banasky
Hi Brian,
My screen looks a little different than yours, but you can create New Line Styles,
and pick them from the list, any Color, Weight or Type.
You can also right click on any object, line etc. and choose any of 16
user created colors.
Edited by user Wednesday, August 29, 2018 12:32:47 PM(UTC)  | Reason: Not specified
New Style.jpg (115kb) downloaded 3 time(s).
brian sayer
#7 Posted : Wednesday, August 29, 2018 12:38:42 PM(UTC)
brian sayer
hi Larry
before i had Shark pro v10 i had Turbocad Mac versions 4 to 8, v7 and v8 being the same as Shark and Viacad
i have been back to older versions and am having the same Issue so maybe its to do with Mac OS?
i think i wil investigate further
Brian
