#1 Posted : Thursday, August 23, 2018 3:43:08 AM(UTC)
The major ACIS bug with "Precise curves" has been solved.
Still there is another one...
To repeat :
- Make a solid cylinder.
- Model to sheet the cylinder
- See all the missing lines (the bottom right view is empty).
- Picture 1
On picture 2 see the result with a real model.
The workaround is to use polylines, but then the dimensions are all slightly wrong - and sometimes TOTALLY wrong : ie a radius 1mm is displayed 0.6mm when I recreate an arc on the polyline.
Regards,
JL
Capture d’écran 2018-08-23 à 11.31.07.png (198kb) downloaded 0 time(s).
Capture d’écran 2018-08-23 à 11.42.21.png (72kb) downloaded 3 time(s).
Antoine
#2 Posted : Tuesday, August 28, 2018 3:33:39 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Salut et merci pour ton post,
Je refuse dorénavant de relater les infinis bug concernant le mode MTS à Tim.
Cela fait 10 ans que nous nous efforçons dans ce sens sans être entendus...
Le mode MTS est malade et est inutilisable pour un professionnel.
Je cherche actuellement un logiciel capable d'importer ma modélisation sous Shark afin de réaliser des plans techniques.... un non sens....
Si vous avez une bonne astuce pour créer ce genre de document techniques, je suis preneur.
Merci.
Antoine
thanks 1 user thanked Antoine for this useful post.
jlm on 8/28/2018(UTC)
GARLIC
#3 Posted : Tuesday, August 28, 2018 4:23:51 AM(UTC)
GARLIC
Was thanked: 103 time(s) in 65 post(s)
Merci.
Antoine
I think you will be quite happy with Solid Edge and/or ANSYS Spaceclaim,
just my 2cts
G.
thanks 1 user thanked GARLIC for this useful post.
flatpack
#4 Posted : Tuesday, August 28, 2018 7:42:15 AM(UTC)
flatpack
Was thanked: 20 time(s) in 15 post(s)
just my 2cts
G.
Too bad no OS X version. Or is there?? :)
#5 Posted : Wednesday, August 29, 2018 11:21:52 AM(UTC)
Originally Posted by: jlm Go to Quoted Post
To repeat :
- Picture 1
Regards,
JL
JL
I am not seeing this repeat here? Can you post your file with the cylinder?
Edited by user Wednesday, August 29, 2018 11:23:50 AM(UTC)  | Reason: Not specified
c1.sfx (33kb) downloaded 3 time(s).
jlm on 8/29/2018(UTC)
#6 Posted : Wednesday, August 29, 2018 4:12:02 PM(UTC)
To repeat :
- Picture 1
Hello Jason,
I'm doing exactly the same cylinder as you do and it's not correct on my views.
It must be a bug on the Mac version.
Lets try the new WIP uploaded today...
Thanks for trying,
JL
#7 Posted : Thursday, August 30, 2018 12:46:46 AM(UTC)
Both issues mentioned here (simple cylinder and complex screw cap) are solved in WIP11 !
There are still some cases of bad display.
Please see attached file where only 3 spheres out of four are displayed in the views...
MTS3.sfx (55kb) downloaded 7 time(s).
Capture d’écran 2018-08-30 à 08.44.47.png (102kb) downloaded 0 time(s).
#8 Posted : Wednesday, March 20, 2019 6:32:19 AM(UTC)
No answer ?
This is just an example with a simple model.
With a complex model it can be much worse and it is sometimes impossible to use "precise curves".
