Solid Modeling
Line Segment woes - SharkCAD 10
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Hello there.. could someone pls take a quick look at the attached Sharkcad 10 file.
All it is is an extruded rectangle with a rectangle hole punched out of it. The rectangle cutout has a blended edge on all four corners.
I tried using Constant Blend Radial and Constant Blend Elliptical.
BUT.. when I make a draw view out of it, AND use PRECISE CURVES, the radiused edges are shown not as one smooth curve, but TWO.
How can i make the draw view show one smooth curve as it ought to be.
Additional Comments:
Circles are a full measurable circle.
Radius is made up from two arcs.
Ideally the radius rectangle box should be selectable as one polyline.
Please help.
radiused corners are split.slt
(89kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 142 times Was thanked: 141 time(s) in 100 post(s)
Just try using the Fillet Two Lines tool.
Seems to work on the rectangle that I copied.
radiused corners are split2.sfx
(65kb) downloaded 0 time(s). L. Banasky attached the following image(s):
(67kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Originally Posted by: L. Banasky Just try using the Fillet Two Lines tool. Seems to work on the rectangle that I copied. Larry
Thanks Larry I tried this and it works; couple questions... are you suggesting its better that I fillet the rectangle corners BEFORE I cut-out the profile from my solid?
As in, is it more "correct modeling" to do so?
Furthermore, do you know if there is a way to edit the fillet radius afterward? It won't allow me to change the radius. Seems to only work with a Blend operation.
Edited by user Monday, August 27, 2018 6:55:05 PM(UTC)
The file you provided was 2D. If creating 3D use the Blend Tool after Extruding, and I think you can edit the Blend. If using the outline to cut out part of a solid, someone else might be able to help, I haven't tried to do that yet. Larry
Originally Posted by: L. Banasky The file you provided was 2D. If creating 3D use the Blend Tool after Extruding, and I think you can edit the Blend. If using the outline to cut out part of a solid, someone else might be able to help, I haven't tried to do that yet. Larry
Sorry I think I turned off the layers that had 3d. They should be on there still.
The only way I can modify with the 2d profile is to just delete the radiused corners and re-fillet. So there is indeed a workaround! Easy enough.
Edited by user Tuesday, August 28, 2018 7:40:01 AM(UTC)
The Deep Select Tool will allow you to select each radius and edit it.
radiused corners are split3.sfx
(71kb) downloaded 1 time(s). L. Banasky attached the following image(s):
(50kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Solid Modeling
